Tapping into the filter block with a known good gauge to verify oil pressure. He reported that his stock gauge reads very high which could be the reason his seals leak. If he really has that high of oil pressure, he likely has a blocked oil passage or stuck relief valve and needs to fix it at once to avoid damage.
